Pause Glyph/symbol for Copy Geometry Feature - Part Modelling
gprasadr
3-Visitor
I have a Pause glyph/Symbol for a Copy Geometry feature inside a Part File.
I know about the Pause glyph in assembly file where it means its constraints are frozen, but no idea about the part modelling.
Tried redefining the feature, keeping parent part in session and in the same working directory.
But if I create any new copy geometry features then there is no pause symbol.
Please help.
Using Creo 2.0 M090
Hi Guru,
I did some searching in our internal TS database and found that older cases that were created regarding the same issue, required the part to be sent in for R&D to fix the error.
If you have maintenance, I would suggest creating a Tech Support case for this issue.  You can create a case here - Case Logger.
Unfortunately, there isn't a straight forward resolution to this issue.
Amit
Hi Amit,
Sorry i am checking in after a long time. Thank you very much for the reply.
I will create a case for this.
Guru
