Piping material file
Matthijs1
When using piping, you can select a material file in LineStock. When I select different materials, nothing happens to the pipe solids. When I change the Weight/Length, the weight of the pipe solids change.
When I change piping_material_source to material_dir, again, nothing changes.
Just want the pipes to get the right weight and appearance.
Is this yet another Creo option that doesn't work or am I missing something?
Using Creo 10
Hi @Matthijs1,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team.
