Plan 2D
ZE_10826055
3-Newcomer
Plan 2D
Does anyone know how to change the dimensions of the drawing lines because when I save in pdf format... I have big lines that appea.
Thanks.
(To:ZE_10826055)
If you open the pdf file in Acrobat reader or Acrobat and then press ctrl+5 it will reduce the line weight of visible lines. Try this and see if it resolves your issue.
If it is a plotting/printing issue, then see this thread.
Solved: Thinner lines when exporting or printing a drawing... - PTC Community
Are you talking about the line thickness when exporting to PDF?
Yes  exactly
(To:ZE_10826055)
It works . thank you very much
