Pro/Engineer Wildfire 5.0 - Insert image/photo in drawing
mselamat
Hi all,
Good day.
Is there any way to insert image/photo into Pro/E drawing work space?
I want to include some screenshot in my drawing.
Is it possible?
Muzzammil
mbonka
(To:mselamat)
Hello Muzzammil Selamat
yes, it is possible. l will describe Creo 2.0 method. Perhaps WF 5. will be simillar.
1. Click insert object
2. Select NEW - Object type "Picture Paintbrush program"
3. Windows Painting window will pop up - CTRL+V desired picture - close Painting windows without saving (upper right corner)
4. Inside drawing space will be an object with picture - you can edit picture size and location
5. Note: Double click picture will open windows Painting program and you can reedit your picture
Hope it can help
Milan Bonka
Hi Milan Bonka,
Thank you for your reply.
I somehow found out the same thing just before your reply.
But still, thanks!
Muzzammil
Dale_Rosema
(To:mselamat)
Don't forget to mark Milan's answer as correct for those who may find this discussion.
