Pro Tip: Creating search paths file quickly.
Michael
16-Pearl
command in windows :
dir /b /s /a:d > folders.txt
This command will output a text file with all the recursive folders found in the current path where the command runs.
it will create a file with all the sub directories recursively found in the starting path, and will write this out to folders.txt. This can be used and renamed to search paths file.
It will save you a lot of time for having to create this file manually.
KenFarley
21-Topaz II
(To:Michael)
Previous discussion with utility (DOS batch) script to do things automatically.
https://community.ptc.com/t5/System-Administration/Config-pro-search-path-quot-relative-quot-path/m-p/540262#M20
Should take care of things like putting quotes around the directory specifications. If any white space is in a directory name, the search.pro file will not work if directories are not surrounded by quotes.
