Hello All,
I am a user of Pro-e WF4.0
My requirement is I need a step file with CoG.
I have a 3D assy model.In that I have added CoG by using coordinate system.
After that I have converted from 3D assy to step file.
If i opened the step file in format of Part , I couldn't see CoG in step file.
What should I do ?
I need your support guys.
Thanks!
Hi, you can create any coordinate system in ProE - for example CoG and then... if you export object from ProE, you can select Coordinate system (do not use default Csys) - select your CoG
