ProMechanica - mpeg export
EBICO
Whenever I export the animation from Mechanica in mpeg format I cannot seem to adjust the playback speed (frame/sec). No matter what setting I try I get the same playback speed in media player after exporting, one that's way to fast to see what's happening.Anyone else with the same issue and possible solution???
SylvainA.
(To:EBICO)
Did you try to increase the duration of the movie (in "MPEG Export" window) ?
I actually had to increase the frame rate and adjust frame rate settings when exporting...it is not user friendly as it could be.
SylvainA.
(To:EBICO)
On my computer (using WF3) when i want to export an analysis result as an mpeg file, I can set frame rate and number of frames or movie duration in second... (the frame rate has to be set to 25 or 30 FPS if you want a good playback in media player)
