Proe AAX Feature not obtained
rdelgado
I have encountered some problem in proe AXX extension, the features cant obtained even it was already configured in ptcsetup.
Please see attached file for your references.
Check the version of AAX license in license. This may happen if license version of AAX is not compatible with current version.
You can check this in license file under Summary table, release column.
Hi Mahesh
Thank you for the reply
Here is the sample license file
FeatureName                               Qty        Product                                                             Release   Type    Expiration     Contract
#127                                              4    Mechanism Design                                                     WF 4.0 PreProd Ext      perm         4A1109410
#210                                              4    Pro/ENGINEER Design Collaboration Extens           WF 4.0 PreProd Ext      perm         4A1109410
#PROBUNDLE_10119                 4    Pro/ENGINEER Advanced Assembly Extension        WF 4.0 PreProd Ext      perm         4A1109410
#127                                              4    Mechanism Design                                                      Wildfire 5.0 Ext      perm         4A1109410
#                                                    4    Windchill ProjectLink - Heavy User Licen  9.0     Flt Opt  perm         4A1109410
#PROE_FoundationAdv               4    Pro/ENGINEER Foundation XE (formerly Fou           WF 4.0 PreProd Flt Lic  perm         4A1109410
#PROE_FoundationAdv               4    Pro/ENGINEER Foundation XE (formerly Fou         Wildfire 5.0 Flt Lic  perm         4A1109410
#PROE_FoundationAdvAAX       4    Pro/ENGINEER Foundation XE (formerly Fou          Wildfire 5.0 Flt Lic  perm         4A1109410
They use wildfire 5.0 M060
Hello Renz,
License for AAX is compatible up to pre-production release of Wildfire 4.0. It will not work with any of the version starting from Pro/ENGINEER Wildfire 4.0 F000. It could be due to maintenance. You may check with PTC License Management.
PROE_FoundationAdvAAX license probably contains AAX. Configure Creo to run this license.
Martin Hanak
Hi Renz,
You may mark appropriate reply to post as correct answer, if that help you.
