Please provide me the resolution for below mentioned issues.
1. How to Create user defined stamps in Creo elements
2.How to add different cross section profiles in Creo elements Sweep feature.
3. How to create automatic BOM in Creo elements Direct Modeling
4. Is it possible to create family table in Creo elements
5. what is Breakthrough option in Creo elements and How does it work.
6 .How to fix Components DOF in Creo elements assembly modeling.
1) create a workplane under the modeling tab and using the 2D line commands create the stamp pattern. Using the Imprint command, imprint the 2D profile onto the part.
2) create a workplane perpendicular to the edge that the profile will be sweeped. Drawing the profile cross section. Using the advanced sweep command in the surfacing add-in module, name the part, select the workplane, select the edge(s), click ok.
3&4) I have never used these features.
5) Not sure what is meant by DOF.
Scott
