Question about Sweep in two seccion
fcano
Good day
I have a question, I'm trying to make an aluminum frame for a freezer but for this requir make a plastic cornerback for joining profiles.
When developing the plastic profile sweep use the tool, which makes me the piece at 90 ° but I require is to make the parts to an internal angle of 90 ° but the outside what I require a radio.
I appreciate your help
10 REPLIES 10
dgschaefer
21-Topaz II
(To:fcano)
I would not make this with a sweep.  I'd extrude one side, cut it at the 45 degree angle, extrude the second side through next and add the radius after with a round feature.
LinkedIn
Hi Doug
I understand what you say, but I can not do an external radio, since the geometry of the part will not let me, let me know if the function sweep I can do two track (1 track 90 ° internal and the second with a radio) ??
rcrerar
(To:fcano)
Surely you would be looking to do a revolved section through 90 degrees making the axis of revolution on the inner corner.
dgschaefer
21-Topaz II
(To:rcrerar)
That depends on the design intent.  Looking at the image, it doesn't look like the outer radius is smaller than a 90 degree revolve would produce.
LinkedIn
Patriot_1776
(To:fcano)
Sony makes a nice "radio" if you require one.....
Jajaja
Ok, my mistake, I mean diameter
kdirth
20-Turquoise
(To:fcano)
Are you looking for something like this?
The curve shown in your image has a radius to small to create this shape in one sweep s the inner surfaces would be self intersecting.  If you are looking to only radius the outer profile, two sweeps, one at a 90 and one with a radius could accomplish that.
fcano
(To:kdirth)
Hello Kevin
It is similar but the inside of the I require 90 °, if conducted in 2 parts the connection between them as I make, since it is internal and external to 90 ° it is with a radius
kdirth
20-Turquoise
(To:fcano)
The inside portion can be made with a 90 and the outside with a radius.  The second curve needs the radius to start and end tangent to the 90 degree portion so that it is a 90 on the inside edge (similar to my previous example).
Kevin
(To:fcano)
It can but the radius needs to be the same as the width of your profile section.
