RES: Product Veiw or Express What do the differnt extensions meen.
grocha
Hi Ron,
.ed files stores produtc structures in older ASCII format, depends of .ol
files containing geometry data
.edz files are kinda "ziped" files that contains both structure and geometry
data
.pvs files are similar to .ed files but in newer format wich means small
files, depends of .ol files too
.pvz files are the same as edz, it contains structure and geometry data in
the same file.
Hope it help you.
Guilherme Rocha
De: Ron Rich [
0 REPLIES 0
