Is there any can we export modelcheck report in Excel.
Amit
Amit,
Excel is not an option but you can import text files (generated on application exit for metrics) in excel format. That may help.
But, Importing text file in excel will give me report in respective column ?
Amit, I think excel has options to maintain columns on import data from text.
Thanks I will try it..
