I'm trying to replace members of a family table (o-rings) in an assembly
with comparable members of a similar family table that was copied from
the first part. In other words, I installed o-rings by vendor part
number in the assembly, then CM says I have to call out our part numbers
for the same part. So I copied the part with the family table, renamed
everything so CM likes it, and when I go to 'replace' the components in
the assembly, Proe doesn't give me the option to pick a different part.
The only choice is to 'replace by copy', which I DON'T want. If I check
'clear', it lets me select the part I want to replace it with, but
'apply' and 'OK' are grayed out. What good is this? The only way to do
this is delete the first part, assemble the second part, then reapply
flexibility, which defeats the purpose of replacing parts.
Does anybody actually do work according to this kind of Proe logic?
Ken Sauter
DRS Reconnaissance Surveillance and Target Acquisition
Infrared Technologies Division
PO Box 740188
Dallas, TX 75374
469-221-5430
NOTICE: This e-mail transmission (and/or the attachments accompanying
it) may contain confidential or proprietary information belonging to DRS
Technologies or the sender. The information is only for the use of the
intended recipient. If you are not the intended recipient you are hereby
notified that any disclosure, copying, distribution or the taking of any
action in reliance on the contents of this information is strictly
prohibited. Any unauthorized interception of this transmission is
illegal under the law. If you have received this transmission in error,
please promptly notify the sender by reply e-mail, and then destroy all
copies of the transmission.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior written approval from the U.S. Department of State."
