Is it possible to represent each sub-assembly and part in the assembly environment of Creo 2.0 parametric exploded view with an item tag (Only with the item part number tag), so that, the same exploded view can be used directly by the user for any business presentations creation.
Please note that, if annotate option is used, it will consume much more time than expected.
Best regards,
Simha
