I have an assemby with a number of short runs of coaxial cable, each with a connector on both ends. I want to use the same cable model in all the different locations. This means that, if my cable is 150mm long, for example, it will be stretched out almost straight in some places, whilst in others it is looped around.
I know how to create my cable in the Cabling module, but I can't work out how to have the same cable fitted in different locations and in different shapes.
Is there a strategy for this?
WF4, m220
Thanks, Brian,
I spent all morning trying this approach.
I was successful to a degree.
I am finding that I can't make large changes to my flexible dimensions. I have to approach the final destination stealthily, by degrees, otherwise it simply ignores the changes I make to the flexible dimensions. Curious.
Also, the Cabling software is, at best, flaky, it seems. The last one I moved, the connector ended up in the right place, but the cable stayed put. Who knows why?
Still, I suppose all this playing with expensive software beats having to actually work for a living...
Off home for the weekend now.
Cheers,
John
