Hi everyone!
We are trying to route ribbon cables in cabling. It works fine, we could do everithing in the 3D environment so far, although when we start to make drawings thigs start to fall apart. Everything that works in normal cable spools doesn't seem to work in ribbon spools. We can't show any data on the dwg from reported parameters, from harness. From pin it works quite well, although we cant show any length parameter in the DWG tables (normally it comes from harn.run.len I believe). So we can't make "from-to" tables from ribbon cables. But all of the info is shown in the modelling environment, we just can't access it in the DWG. The "from-to" is not critical with ribbon cables, we can live with the lack of that, but a cut table would be nice to have on the DWG. Is there a methot for this? Do We have to access these parameters from somewhere else like asm.mbr...... ??
Best regards!
Laszlo
