Saving an assembly with associated part drawings
DanAdler
Is it possible to save an assembly of parts with the 2d drawings of each part and of the assembly in a single file for sharing outside of my organization? The drawings need to maintain associativity obviously. We use model manager inside of organization so this hasn't come up before.
An Assembly + one (assembly) drawing can be saved as Bundle (.BDL) File out of Modeling/Annotation,
but there is no OOTB solution for an assembly together with multiple drawings.
I make a top level assembly into which everything reports.  Then I let that assembly be the owner for my (1) drawing.  When I want a 2d drawing of a sub-assembly or component, I create a sheet, then modify the contents to only include that sub-assembly or component.  This way your bundle file has only one "drawing", but each sheet represents the 2D for the details of a sub-assembly or component.  Save the whole thing as a bundle file.  It's a bit tedious as a work-around, but it keeps everything together in a single file.
Hello Daniel,
put the assembly and the 2d drawings who belongs to it in a .zip so you have one file .
Best regards and have nice weekend
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
DanAdler
(To:DanAdler)
Thanks for all of the replies. The assembly in question has hundreds of parts with hundreds of drawings so the workarounds mentioned would just take too much extra work.
