Hello People,
Here it comes my question.
I have a structure connected with the ground (I don't have Information about material of the ground).
Screws: M56*200mm (8.8)
Preload (tables): 1097 KN
There are Loads on the structure in different directions, so I want to see (It´s not the main research in the simulation), how It is affected to the housing (stress, displacement).
Under my structure I have defined a fixed constraint in all axis.
How can I set the screws?
If I create a connection>fastener into simulate, I have no edge at 200mm (because there is no hole).
I attach photo. Thanks a lot!
