Shaft or HelicalSweep feature
VladimirPalffy
4K resolution (3840x2160) of a shaft  - modeled and rendered with PTC Creo Parametric 2.0 (PTC Creo Advanced Rendering)
Vladimir
Best Regards,
Vladimir Palffy
0 REPLIES 0
