Anne, when you created your part did you start and only use the sheet metal mode? I have seen parts made using a solid model that are able to convert to a sheet metal model, but due to the nature of the part certain features are not accessible. ie - flat pattern.
I have made a curved part in the past. This part had a varying radius however this was only in two dimensions with the sketch extruded to make the sheet itself. I am surprised to see that in the least, Pro/E did not just consider the problem areas a deformation and continue on from there.
