Sir/mam,
I made one base model in sheet metal and creates 7 instances. on that instances there are holes, on every instance the position of holes is different, I want to do mfg drawing for each instance but when I take the flat pattern it opens with base model. how I take the flat pattern for instances?
Anil Patil
9960552668
