In Creo 3.0 how can I use "Show Model Annotations" or a similar command to show hole centermarks of a part in a drawing of a subasembly that part is in?
In Wildfire, the Show/Erase command didn't care what level the centermarks were on, it just showed them in the drawing.
click show/erase and click on the part in the tree.
