Show parent at top of flat repeat region (drawing bom table)
wcash
5-Regular Member
Can I configure a Drawing repeat region (bom table) that shows parent assembly on first line followed by only first bom level components?  Recursive table shows parent at top but shows all bom levels.  Flat table shows first level bom only but does not show parent at top.  I am using Creo 9.0.2.0
MartinHanak
24-Ruby II
(To:wcash)
set Recursive option and add following Filter
&rpt.level <= 2
MartinHanak
24-Ruby II
(To:wcash)
&rpt.level <= 2
wcash
5-Regular Member
(To:MartinHanak)
Works perfectly.  Thank you Martin.
