Hi all,
is it possible to get/show simp rep in note/table?
I would like to have sth similar to assembly process - every sheets show different stage of assembling. Stages are created as simp rep. Each sheet as a note or in table should display name/description of particular stage.
Thanks in advance for the consideration
Best Regards,
Krzysztof
An interesting idea. An ordinary callout can't talk to 'a specific simp rep of an assembly', though it could to a simp rep of a part.
However, it would be possible to have a callout 'the name/type/rep/step [four separate callouts] of the top model in a specified view'.
To request this, please make a Product Idea. It would be fairly simple to implement, but might want to show that it will benefit a number of users.
I would strongly advise you not to go down this path and instead use tools that are intended to document assembly instructions. Pro Process and or Creo Illustrate
