Why can't I change the sketch setup when drawing the sweep section ?
The default view is upside down and all twisted...
Can't draw this way !
There are no apparent options on the sweep setup that I can play with to change this...
If I select a different X direction, it does not allow me to sketch.
Evidently, changing the view to a Named View is not the idea here, whether it does the job.
