Hi all,
I'm trying to figure out how big of a hard drive partition I need to run Creo on a Mac using Bootcamp. The only "system requirement" type info I can find online talks about RAM requirements, not hard drive space. I've read that I need at least 20GB just for installing windows, but how much more do I need to add to install Creo and its generated files? I would be doing a relatively small number of parts and assemblies.
Thanks in advance!!
Lauren
my PTC directory is about 50 meg. No design work in there.
If that helps.
wow, that's a lot less than I was expecting to hear. thanks for the response!
i'd be interested to hear if other people have seen about the same thing or not.
thanks!!
oops wrong directory! sorry it's little over 4 gig.
I looked at the 32 bit directory.
the 64 bit one is about 4.2 gig.
heh, thanks! that makes a lot more sense...
