ist es möglich, eine komplette Baugruppe, bezüglich einer Ebene, zu spiegeln?
Lg
Translated:
Mirroring a complete assembly
Is it possible to mirror a complete assembly with respect to a plane?
Lg
Hi Martin,
The symmetry is executed about the XY plane exclusively
The symmetry around a point or any other plane is not part of Creo Parametric functionalities
Amit
