Squircle shaped cylinder in creo
anegi
How to draw a Squircle shaped cylinder in creo.
21-Topaz II
(To:anegi)
Use the curve from equation functionality.
https://support.ptc.com/help/creo/creo_pma/r9.0/usascii/index.html#page/part_modeling/part_modeling/Example_Creating_a_Datum_Curve_from_an_Equation.html
The parametric equations for a superellipse are used to define the geometry of a squircle. You can do this in Cartesian or polar coordinates.
21-Topaz II
(To:anegi)
21-Topaz II
(To:tbraxton)
I would evaluate the math on this as Creo represents the curves if you plan to use this as a cam profile. The curvature plot does not look right to me when using the Cartesian parametric representation of a superellipse configured to form a squircle shown in red.
anegi
(To:tbraxton)
how to add equation for this curve?
MartinHanak
24-Ruby II
(To:anegi)
anegi
(To:MartinHanak)
Thanks for your support.
I have made the shape using the equation available on the web.
21-Topaz II
(To:anegi)
Use the curve from equation function. The Cartesian equation of a superellipse is used to create the squircle.
