I need some other standard tables than those that are availible. ISO, UNC and UNF.
I have ones seen a costumer that had european pipe threads in the Hole tool.
They had a list like:
ISO
Pipe
UNC
UNF
I want that.
How shall the text file be made?
where most I put it?
suggest to check out these threads, and the links within, perhaps a search on ".hol file"
as far as where to put them depends on how your system is set up.
I have mine at a central location and point to it so all can use them with a
config.pro option that is available: hole_parameter_file_path <location> (ie mine is: T:\lib\hole)
by default, it is at c:/program files/ptc/<version>/common files/<build>/text/hole
Yes almost there.
That led me to Document - CS28399 at the PTC homepage.
That gives me almost all info that I need.
The qestion now is how do I edit a .hol file
just open it in your favorite text editor
