Status Bar overrides Message Text Area?
Pieface
6-Contributor
Anyone encounter the Status Bar overriding the Message Text area in Creo?  This is only occurring while I am in a drawing.  Have no idea how this happened and there appears to be no way to fix it.  I am suspecting my poor eyesight which requires 125% Text Size might be causing the issue.  The 125% text size has caused issues in other areas of Creo.
Hi Don,
I have not seen this issue before, and I think it may be caused by the resolution of the monitor.
Amit
Pieface
6-Contributor
(To:AmitDeshpande)
Hello Amit, the issue went away with a new session, but, it will be back at some point in time.  It also occurred with an assembly and I have previously seen it.  I will blame the 125% font size which affects other windows such as Model Setup.
As shown below for the same drawing the issue no longer exists.
