Step to Pro part
ptc-1428410
Step to Pro part
Hi everybody, I have to convert step file to pro-part, Can I get any tool to remove radius for imported step parts, as I create radius using "fillet" feature? Regards Venu
The data doctor will be able to remove that feature, but it is not a fast edit. You must have a license of the data doctor to edit the feature. Check you license under the help tech support and see if data doctor is loaded. Then you should be able to rmb click the the import (first feature) in the model tree and a new set of tools comes up for your use. Good Luck Eric
Hi, Thanks for ur reply If I click on first feature (RMB -> Edit definition) Pro-e gives few set of tools, they can use only for Imported files (Geometry - Heal gometry etc.....) If u r telling abt that category, there is no such a tool, we can remove the radius directly. Regards VEnu
Yes. You can remove the fillets from imported geometry. In wildfire 4 there is an option called "REMOVE" in "EDIT". Just click the fillet you want to remove & click the "REMOVE" option. The feature will remove the fillet & surfaces will get extended. -Sachin
