Summary: Annotations & Layers
dgschaefer
21-Topaz II
So, it seems that PTC removed the ability to control annotations by layer in Creo 1.0 [1]. They recommend using "Combined Views" instead [2], which is fine if you're doing model based definitions, but it's a cumbersome substitute if you just need to see a note on screen occasionally.
I created a Product Idea on PTC's website [3], if you'd like this functionality restored, please go and vote.
[1] - https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS39449
LinkedIn
0 REPLIES 0
