Is it possible to trim a radial axis pattern centerline ina drawing? ie: A bolt hole pattern centerline?
Solution: Turn view into a partial view and cut off the excess centerline with view spline. So easy I couldn't see it staring me in the face. Thanks to all who replied so quickly. Wayne, I agree this isn't a preferred method, but for these parts which are made in house, it will work. Thanks!
Chris
