Afternoon,
Just fishing around to see if anyone out there has users running Creo on a Surface Studio 2? I am interested in hearing about any challenges or wins that you have run into while using these consoles along with anything else anyone might know. I am actively testing one so action based feedback is fully acceptable.
Thanks in advance.
Correct. I assumed the forums had 2 different audiences based on their content and there may be cross over.
So far I am finding that the surface 2 is not suited for detail design if you want to use the stylus. There is no middle mouse button to end commands and sketching does not register when you have completed a rectangle, circle, etc - the sketch geometry remains active.
