Please see the attached files.
"proe_note.txt" ~ Note as typed in note editor.
"proe_dwg.pdf" ~ Note as it appears on the drawing.
Is there a way to format this note to get rid of the space as indicated and to center, vertically, the symbol (circle) in the first line of text?
Tall order!
Greg,
Can you put the symbol on a line by itself? Other option is to leave a space in the note for this symbol and then place the note (symbol only) using “offset” placement relative to the other note, so that they move together.
BillGreg,
A couple of things. First, I noticed a space after your symbol name (fai_callout). I'd probably remove it. Second, have you tried using superscript via @+ & @# to close the superscript portion? I think that'd work. If it doesn't, I think the symbol may have something going on, perhaps a space or return. It depends on how the symbol was created. HTH.
Rich
