Set def_view_text_height to .25 in your .dlt file. This affects the view text and the cross section text.......you may have to add this line.
Can't help so far on the text/font style........perhaps def_view_text_thickness would help?
John Isles
Mold Designer
WF4 has a new drawing option or two to deal with view notes...but I still don't think it will give you everything you want.
I assume the defaulttext height for most of your drawing issmaller than .25, and you want the entire view label to be larger at .25 high. As mentioned previously, you can change the height of the view identification letters using def_view_text_height. However, this will not change the height of the view label prefix (e.g., SECTION or VIEW). That needs to be done manually if you want them to be the same size and a different height from the default drawing text heigh.
You canat least control the justification of the newnotes now with default_view_label_placement, so they are not always shifted off to the left or right of the center of your view. One piece of what has been requested to be added to this functionsince probably 1995.
