Text style issues in a drawing
DK_7517006
I am using Creo Parametric 8.0 8.0.1.0
When I make a drawing, I load a drawing format file. The tables in the drawing format have custom text styles for different character heights, spacing, etc. Now with this latest update to Creo 8, when I type in a cell in a table, the text styles automatically reset to a default, and override the custom settings in the format. Is there a way to make Creo recognize the text styles that are saved in the drawing format?
TomU
(To:DK_7517006)
There is a known issue where table cells are losing their formatting and reverting back to the drawing's default font and text height. This will be corrected in 7.0.7.0, 8.0.3.0, and 9.0.0.0.  See https://www.ptc.com/en/support/article/CS352195 for more info.
TomU
(To:DK_7517006)
That explains my issue exactly!  Thanks for the feedback.
Patriot_1776
(To:TomU)
Huh, that's weird, because it's been happening to me ever since we switched from Creo 3 to Creo 4, and it's annoying AF.  It's not the height that changes, it's the style.  Looks like there isn't a cure for now then for Creo 4.  Yay...
