Is there an option so that the threaded hole created by creo isn't hidden by default? The clearance holes are not hidden.
OK. So can you please mark this as solved.
Thanks.
I have tested this in Creo 4.0 M030 right now. All holes are visible.
Maybe you have a Layer configuration which hides all holes.
Please create a hole feature without IFX and check if it is visible.
IFX has no functionalty to hide created holes. Don't know if there exist a Creo option to do this.
I believe you are right. It looks like it is just a layer status issue with cosmetic features
