Tolerance overlap issue
cchin
Tolerance overlapping when add tolerance dimension (plus/minus) in the drawing part. How to fix it? Thanks.
I attached with an example of issue.
sgupta-2
(To:cchin)
Hello Chin,
Height and width of the tolerance text are controlle by the following two drawing setup file options.
TOL_TEXT_HEIGHT_FACTOR
TOL_TEXT_WIDTH_FACTOR
cchin
(To:sgupta-2)
I did following set up to TOL_TEXT_HEIGHT_FACTOR and TOL_TEXT_WIDTH_FACTOR .
The text height and width factor change on a line. but, the tolerance plus and minus (2 line) still overlap.
please advise. Thanks
Chin
TomD.inPDX
17-Peridot
(To:cchin)
If this is Creo 3 and you have maintenance, please submit a support case so this can resolved if it is indeed a bug.
You can also see if this is a configuration problem by opening Creo as a default install. Then changing the settings one at a time to get to what your standard is.
I do not use this style dimensioning. Normally I just sneak up on these settings one at a time. It makes sense to start with a clean slate.
sgupta-2
(To:cchin)
set text_height 2.5
set TOL_TEXT_HEIGHT_FACTOR 1 for ANSI and 0.6 for ISO
Mahesh_Sharma
22-Sapphire I
(To:cchin)
For a quick trial set drawing option update_drawing as all and update the drawing. (Open drawing, File > drawing options > Add update_drawing under option name and all under value > Add/Change > Close)
Hi Chin chin,
Still you do not find any solutions please upload the model & drawing.
Thangavijay T
