Creo 3.0 M100 with Windchill 11.
Since the "upgrade" from 2.0 to 3.0 one of the many problems we've had, one that I've not been able to resolve or find a workaround for, is the placement of offset symbols.
Note flag, KPC diamonds, gage number callouts, etc... we've always used the Placement>Offset & attached it to the dimension & notes. When revising the drawing of a part or assy, quite often when moving the dim or symbol, suddenly it seems to get snapped to a slightly different location. So I move it where I need it. Refresh views, snap, right back to the incorrect location. I can delete the symbol(s), place them in the drawing again & have the same result.
What gives? I tried searching the community using the filter but was unable to locate anything about this.
Joe
OK, opened a ticket with tech support. They were unable to fix it so far & requested a copy of drawing that has the issue. If they can figure it out, I will post the answer here.
I've been using PTC's CAD product (Creo, WF, ProE thanks marketing for confusing everyone) for a long time. Creo 3.0 is giving me & my users nothing but grief. No improvements, just moving things around & in most cases making it more difficult to use. Text editing in drawings is a nightmare where it used to be quite easy. Thanks to M100 I can still do it the old way but selecting & editing is tricky & results in multiple clicks to select the object.
