Two-D repeat region, hide column
ptc-3121086
How can I hide/delete a column in a Two-D repeat region created from a family table? I have a user defined parameter in the family table because if I don't then the generic and all instances will have the same value for the parameter. I need to then hide that parameter because it becomes redundant in the generated Two-D table. Thanks.
Kevin You can do two things, one remove the &parameter callout in the table, or two remove the entire column from the table. Both options applying to repeat region.
Yes, both options apply to a SIMPLE Repeat Region. Those options will not work for a TWO-D Repeat Region used with a family table that has more than one parameter.
Table > Repeat Region... > Filters &fam.inst.param != PARAMETER_NAME_YOU_WISH_TO_REMOVE, PARAMETER_NAME_YOU_WISH_TO_REMOVE_2 or &fam.inst.param == PARAM_TO_KEEP, PARAM_TO_KEEP_2, etc.
Correction: &fam.inst.param.name != or &fam.inst.param.name == Hope this helps. Rodney
