Two arrow with difference style in one dimension line
Hongjie
I am look forward to express a dimension line with two difference arrow type styles. Just like below photo, one end is standrd arrow and other end is dot, it is possible in Creo 2.0?
All my try show only one type style, boh standdrd arrow, or both dot, it is impossible to mix arrow and dot. thank you in ahead and have a nice weekend.
Best reagrds, Hongjie
StephenW
(To:Hongjie)
In Creo 3, if you select the dimension and then hover the mouse over the arrow, right click, you can change the arrow on one side only.
I don't remember if it works like that in Creo 2, you'll have to try it.
StephenW
(To:Hongjie)
mbonka
(To:StephenW)
Creo 2.0 M200 is the same method.
Only pop-up menu looks a little bit different...
Milan Bonka
Hongjie
(To:mbonka)
Hi Milan
it work in my Creo 2.0, M240, thank you.
Hongjie
(To:Hongjie)
Hi Stephen,
pre choice the dimension and hove to find the arrow disappear( need a little patinet)  then right clik to show arrow style promt.
thank you veru much!
