Is there a way to assemble an External Simplified Representation into another assembly? I'm using Creo 2.0. I get an error message as below
I think that is not possible. The use of an External Simplified Representation is as a shortcut to the basis assembly, not as a standalone item that is a replacement for an assembly.
I recommend reading all the PTC responses in the following message. There is a long passage from Gunter that I won't copy here.
per http://communities.ptc.com/message/252525#252525
No. ESR cannot be assembled to another assembly.
Further in the same message :
The intended use of ESR tool was to let "system architects" a way to prepare "work packages" and distribute them to the team w/o forcing them to ever download nor modify the higher level assembly(s).
Purpose of ESR is to store a simprep definition in a separate file that does NOT force user(s) to modify the top assembly object and/or interact with an internal simprep that is defined in the top assembly.
Realistically - in very large assembly scenarios - only the integrator(s) or very few users will actualy have access to the top assembly for editing, while each designer will likely have access to the systems of one's responsibility.
