Unable to resize the new window in Creo2.0
amitshah
I am using Creo2.0, Where I have configured EFX or AFX (formerly known as Expert frame work).
When I select profile option, a new window appears but I could not see OK/done button.
I have tried to drag and resize window but still the options are hidding behind Windows task bar.
The same issue reproduces while I try to go for SAVE A COPY option of an assembly.
I am using DELL Precision M4600 mobile workstation.
Did anyone came across this issue?????
Amit
Dale_Rosema
(To:amitshah)
I had something similar to that, but not in those specific portions of the software:
http://communities.ptc.com/message/187851#187851
Here is the thread from that time.
