Unable to select shading from 2D drawing - display style
JW_10714096
Hi
I am following the tutorial steps and I am trying to select the shading from display style for 2D. However, the system does not allow me to select it. Is t
9 REPLIES 9
AH_10565398
(To:JW_10714096)
Can you select it in the model itself?
I am not sure. I can select it from the mini tool bar on the top of the drawing window
StephenW
(To:JW_10714096)
My guess the view has a cross section. You can't shade a view with a cross section added.
no cross section
Do you have the following config option enabled?
enable_shaded_view_in_drawings
yes. This is enabled
Hi @JW_10714096
I think below is the only option to enable disable shaded views in drawing.
Please check again in your config file. Set above config to Yes.
Jignesh.
I selected different models. All of them had the same issue.
@JW_10714096 wrote:
Hi
please do following test:
  • create new General View in drawing
  • click View Display option in left pane
  • set Display style to Shading
Notes:
  • General View enables you to set Display style to Shading
  • some other view types does not enable you Display style to Shading ... what view type do you use?
