Today a user tweeted the following issue to @ptc_Creo:
"I need to figure out how to turn off plane visibility. Here's what I'm talking about. Planes everywhere:
I can right click on each plane and hide it, but that's a bit tedious. They didn't show up until I reopened file."
And here is the answer from a PM:
"If he’s on Creo 1.0 (guessing based on the white background of the screenshot)
There is an icon in the Graphics Toolbar that controls the datum display:
In the future, he can consider the Command Search tool to find a command. The Command Search can be accessed from the upper right of the Creo window:
Hope this helps!
^LC
