This is what I have so far. Problem comes in when trying to select & delete the format tables on each sheet. Been at this for 2 weeks already and probably have 2 more to go at this pace.
Any help would be greatly appreciated. Help files not very helpful.
Public Sub change_sheet_parameter()
Dim conn As IpfcAsyncConnection
Dim cAC As CCpfcAsyncConnection
Dim CreoSession As IpfcBaseSession
Dim CreoDRW As IpfcModel
Dim sheetData As IpfcSheetData
Dim sheetowner As IpfcSheetOwner
Dim ModelItem As New CMpfcModelItem
Dim sheetInfo As IpfcSheetInfo
Dim paramOwn As IpfcParameterOwner
Dim ipREVISION_LEVEL As IpfcParameter
Dim ipbREVISION_LEVEL As IpfcBaseParameter
Dim pnREVISION_LEVEL As String
Dim REVISION_LEVELnv As IpfcParamValue
Dim ipDRAWING_NUMBER As IpfcParameter
Dim ipbDRAWING_NUMBER As IpfcBaseParameter
Dim pnDRAWING_NUMBER As String
Dim DRAWING_NUMBERnv As IpfcParamValue
Dim ipRMSS_APPROVED As IpfcParameter
Dim ipbRMSS_APPROVED As IpfcBaseParameter
Dim pnRMSS_APPROVED As String
Dim RMSS_APPROVEDnv As IpfcParamValue
Dim ipRMSS_APPROVE_DATE As IpfcParameter
Dim ipbRMSS_APPROVE_DATE As IpfcBaseParameter
Dim pnRMSS_APPROVE_DATE As String
Dim RMSS_APPROVE_DATEnv As IpfcParamValue
Dim ipRMSS_CUSTOMER_REV As IpfcParameter
Dim ipbRMSS_CUSTOMER_REV As IpfcBaseParameter
Dim pnRMSS_CUSTOMER_REV As String
Dim RMSS_CUSTOMER_REVnv As IpfcParamValue
Dim ipRMSS_DRAWN_BY As IpfcParameter
Dim ipbRMSS_DRAWN_BY As IpfcBaseParameter
Dim pnRMSS_DRAWN_BY As String
Dim RMSS_DRAWN_BYnv As IpfcParamValue
Dim ipRMSS_ECO_NUM As IpfcParameter
Dim ipbRMSS_ECO_NUM As IpfcBaseParameter
Dim pnRMSS_ECO_NUM As String
Dim TRMSS_ECO_NUMnv As IpfcParamValue
Dim ipRMSS_ENGR As IpfcParameter
Dim ipbRMSS_ENGR As IpfcBaseParameter
Dim pnRMSS_ENGR As String
Dim RMSS_ENGRnv As IpfcParamValue
Dim ipRMSS_PART_NUM As IpfcParameter
Dim ipbRMSS_PART_NUM As IpfcBaseParameter
Dim pnRMSS_PART_NUM As String
Dim RMSS_PART_NUMnv As IpfcParamValue
Dim ipRMSS_REV As IpfcParameter
Dim ipbRMSS_REV As IpfcBaseParameter
Dim pnRMSS_REV As String
Dim RMSS_REVnv As IpfcParamValue
Dim ipRMSS_REV_DESCR As IpfcParameter
Dim ipbRMSS_REV_DESCR As IpfcBaseParameter
Dim pnRMSS_REV_DESCR As String
Dim TRMSS_REV_DESCRnv As IpfcParamValue
pnDRAWING_NUMBER = "DRAWING_NUMBER"
pnREVISION_LEVEL = "REVISION_LEVEL"
pnRMSS_APPROVED = "RMSS_APPROVED"
pnRMSS_APPROVE_DATE = "RMSS_APPROVE_DATE"
pnRMSS_CUSTOMER_REV = "RMSS_CUSTOMER_REV"
pnRMSS_DRAWN_BY = "RMSS_DRAWN_BY"
pnRMSS_ECO_NUM = "RMSS_ECO_NUM"
pnRMSS_ENGR = "RMSS_ENGR"
pnRMSS_PART_NUM = "RMSS_PART_NUM"
pnRMSS_REV = "RMSS_REV"
pnRMSS_REV_DESCR = "RMSS_REV_DESCR"
Dim workDir As String
Dim sFileName As String
workDir = "C:\Users\jakirsten\Documents\Creo_TEMP"
'MsgBox "Run 01_PURGE_FIRST_Jan.exe First!!!"
Set cAC = New CCpfcAsyncConnection
Set conn = cAC.Connect("", "", ".", 5)
Set CreoSession = conn.session
CreoSession.ChangeDirectory (workDir)
Dim oModelDescriptorCreate As New CCpfcModelDescriptor
Dim oModelDescriptor As IpfcModelDescriptor
sFileName = Dir(CreoSession.GetCurrentDirectory & "\*.drw*")
'sFileName = "4360120-01.drw" 'Name of the drawing
Do Until sFileName = ""
Debug.Print sFileName
Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_DRAWING, sFileName, Null)
Set CreoDRW = CreoSession.RetrieveModel(oModelDescriptor)
Set sheetowner = CreoDRW
Dim oWindow As pfcls.IpfcWindow
Set oWindow = CreoSession.OpenFile(oModelDescriptor)
oWindow.Activate
'sheetowner.RegenerateSheet (1)
Dim curSheetNum As Long
Dim totalSheets As Long
Dim sheetStep As Long
curSheetNum = sheetowner.CurrentSheetNumber
totalSheets = sheetowner.NumberOfSheets
For sheetStep = curSheetNum To totalSheets
Dim tableObj As IpfcTableOwner
Dim tableToDelete As IpfcTableOwner
Dim table_list As CpfcTables
Dim tableInfo As CpfcTable
Dim CurTABLE As IpfcTable
Dim tblCount, tblStp As Integer
Set tableObj = sheetowner
Set table_list = tableObj.ListTables
tblCount = table_list.Count
For tblStp = 0 To tblCount - 1
Set CurTABLE = table_list.item(tblStp)
' Set tableToDelete = CurTABLE
'tableInfo = CurTABLE
'Debug.Print tableInfo.GetName & " is table name"
If (CurTABLE.CheckIfIsFromFormat(sheetStep) = True And CurTABLE.GetSegmentSheet(0) = sheetStep) Then
'Set tableToDelete = CurTABLE
'tabletodelete.DeleteTable(CurTABLE, False) <-------------------------------------Cannot get this to work
Debug.Print tblStp & " is a format table"
Else
Debug.Print tblStp & " NOT A FORMAT TABLE"
End If
tblStp = tblStp + 1
Next tblStp
tblStp = 0
Next sheetStep
sheetStep = 0
Set paramOwn = CreoDRW
' Set ipTITLE1 = paramOwn.GetParam(pnTITLE1)
' Set ipbTITLE1 = ipTITLE1
Set ipREVISION_LEVEL = paramOwn.GetParam(pnREVISION_LEVEL)
Set ipbREVISION_LEVEL = ipREVISION_LEVEL
Set ipDRAWING_NUMBER = paramOwn.GetParam(pnDRAWING_NUMBER)
Set ipbDRAWING_NUMBER = ipDRAWING_NUMBER
Set ipRMSS_APPROVED = paramOwn.GetParam(pnRMSS_APPROVED)
Set ipbRMSS_APPROVED = ipRMSS_APPROVED
Set ipRMSS_APPROVE_DATE = paramOwn.GetParam(pnRMSS_APPROVE_DATE)
Set ipbRMSS_APPROVE_DATE = ipRMSS_APPROVE_DATE
Set ipRMSS_CUSTOMER_REV = paramOwn.GetParam(pnRMSS_CUSTOMER_REV)
Set ipbRMSS_CUSTOMER_REV = ipRMSS_CUSTOMER_REV
Set ipRMSS_DRAWN_BY = paramOwn.GetParam(pnRMSS_DRAWN_BY)
Set ipbRMSS_DRAWN_BY = ipRMSS_DRAWN_BY
Set ipRMSS_ECO_NUM = paramOwn.GetParam(pnRMSS_ECO_NUM)
Set ipbRMSS_ECO_NUM = ipRMSS_ECO_NUM
Set ipRMSS_ENGR = paramOwn.GetParam(pnRMSS_ENGR)
Set ipbRMSS_ENGR = ipRMSS_ENGR
Set ipRMSS_PART_NUM = paramOwn.GetParam(pnRMSS_PART_NUM)
Set ipbRMSS_PART_NUM = ipRMSS_PART_NUM
Set ipRMSS_REV = paramOwn.GetParam(pnRMSS_REV)
Set ipbRMSS_REV = ipRMSS_REV
Set ipRMSS_REV_DESCR = paramOwn.GetParam(pnRMSS_REV_DESCR)
Set ipbRMSS_REV_DESCR = ipRMSS_REV_DESCR
Set DRAWING_NUMBERnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B9").Value)
Set REVISION_LEVELnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B10").Value)
Set RMSS_APPROVEDnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B11").Value)
Set RMSS_APPROVE_DATEnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B12").Value)
Set RMSS_CUSTOMER_REVnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B13").Value)
Set RMSS_DRAWN_BYnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B14").Value)
Set RMSS_ECO_NUMnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B15").Value)
Set RMSS_ENGRnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B16").Value)
Set RMSS_PART_NUMnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B17").Value)
Set RMSS_REVnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B18").Value)
Set RMSS_REV_DESCRnv = ModelItem.CreateStringParamValue(sheets("Parameters").Range("B19").Value)
ipbDRAWING_NUMBER.Value = DRAWING_NUMBERnv
ipbREVISION_LEVEL.Value = REVISION_LEVELnv
ipbRMSS_APPROVED.Value = RMSS_APPROVEDnv
ipbRMSS_APPROVE_DATE.Value = RMSS_APPROVE_DATEnv
ipbRMSS_CUSTOMER_REV.Value = RMSS_CUSTOMER_REVnv
ipbRMSS_DRAWN_BY.Value = RMSS_DRAWN_BYnv
ipbRMSS_ECO_NUM.Value = RMSS_ECO_NUMnv
ipbRMSS_ENGR.Value = RMSS_ENGRnv
ipbRMSS_PART_NUM.Value = RMSS_PART_NUMnv
ipbRMSS_REV.Value = RMSS_REVnv
ipbRMSS_REV_DESCR.Value = RMSS_REV_DESCRnv
oWindow.Close
'CreoSession.EraseUndisplayedModels
sFileName = Dir
Loop
'End the Creo Parametric session when done
''''If Not conn Is Nothing Then
'''' If conn.IsRunning Then
'''' conn.End
'''' End If
''''End If
''''RunError:
'''' If Err.Number <> 0 Then
'''' MsgBox "Process Failed : Unknown error occured." + Chr(13) + _
'''' "Error No: " + CStr(Err.Number) + Chr(13) + _
'''' "Error: " + Err.Description, vbCritical, "Error"
'''' If Not conn Is Nothing Then
'''' conn.End
'''' End If
'''' End If
'''' End If
Set cAC = Nothing
Set conn = Nothing
Set CreoSession = Nothing
Set CreoDRW = Nothing
End Sub
After fighting this for 4 weeks finally got it solved. Had a lot of help from Liu at PTC tech support. Sharing so if someone wants to do the same thing, then he/she would not have to re-invent the wheel. This works on Creo 3.0. using Excel VBA.
Public Sub ReplaceSheetFormats()
'On Error GoTo RunError 'and run KillCreoAfterCrash1
'MsgBox "Run 01_PURGE_FIRST_Jan.exe First!!!" '<----------------------- Would like to run a PURGE on this directory before everything started but suspect something is wron in my settings. Is there an easy way to do??
'------Setup connection to Creo
Set conn = cAC.start("C:\Program Files\PTC\Creo 3.0\M070\Parametric\bin\parametric.exe", Null)
'-----Connected & changed working directory
' Dim dwFilesLists As Istringseq
' Set dwFilesLists = CreoSession.ListFiles("*.drw", EpfcFILE_LIST_LATEST, workDir)
Do Until sFileName = "" 'See Loop down below all this is done on each drawing in the directory
'Debug.Print sFileName
Dim descModelCreate As CCpfcModelDescriptor
Dim descModel As IpfcModelDescriptor
Dim CreoModel As IpfcModel
Set descModelCreate = New CCpfcModelDescriptor
Set descModel = descModelCreate.Create(EpfcModelType.EpfcMDL_DRAWING, sFileName, Null)
Set CreoModel = CreoSession.RetrieveModel(descModel)
Set oWindow = CreoSession.OpenFile(descModel)
oWindow.Activate
Dim thisDrawingName As String
thisDrawingName = CreoModel.CommonName
'VB api process calls and other processing to be done
Dim sheetOwner As IpfcSheetOwner
Set sheetOwner = CreoModel
totalSheets = sheetOwner.NumberOfSheets
sheetOwner.CurrentSheetNumber = 1
sheetOwner.RegenerateSheet (1)
'First delete all format tables from all sheets
Dim tableOwner As IpfcTableOwner
Set tableOwner = CreoSession.CurrentModel
Dim tables As IpfcTables
Set tables = tableOwner.ListTables()
Dim i As Integer
For i = 0 To tables.Count - 1
If tables.item(i).CheckIfIsFromFormat(i) = True Then
tableOwner.DeleteTable tables.item(i), True '<-------------------Thank you so much Frank you are a genius!!! it works great!!!
End If
Next i
Set tables = tableOwner.ListTables() 'just to check tables has been deleted
'++++++++++++++++++++++++Deleting balloons+++++++++++++++++++++++++++++++ Code from Frank Liu....thank you
Dim mdlItemOwner As IpfcModelItemOwner
Set mdlItemOwner = CreoSession.CurrentModel
Dim symInsts As IpfcModelItems
Set symInsts = mdlItemOwner.ListItems(EpfcModelItemType.EpfcITEM_DTL_SYM_INSTANCE)
For i = 0 To symInsts.Count - 1
Dim symInst As IpfcDetailSymbolInstItem
Set symInst = symInsts.item(i)
Dim symInstDefName As String
symInstDefName = symInst.GetInstructions(False).symbolDef.GetInstructions().name
'If symInstDefName Like "*REV*" Then
If StrComp(UCase(symInstDefName), "REV", vbTextCompare) = 0 Then
On Error Resume Next
symInst.Remove
On Error GoTo 0
End If
Next
'Now set parameters for sheetformat: ECO, dates, engineer,... and all that
'From Medtronic parameters 3/22/18
'WM=Windchill rev & not editable
'PTC_WM_REVISION same as REVISION_LEVEL
'REVISION_LEVEL ---- is it safe to use this?
'DRAWING_NUMBER ----not neccisarily Part Number----find partnumber variable!
'&DRAWING_NUMBER:D --- is this the exact variable?
'ITEM_DESCRIPTION
Set paramOwn = CreoModel
Dim CreoModelItem As CMpfcModelItem
Set CreoModelItem = New CMpfcModelItem
Dim ListTheseParameters As IpfcParameters
Set ListTheseParameters = paramOwn.ListParams
'First read the current rev from the drawing
' Dim MedtrWindchillRev As IpfcParameter
' Set MedtrWindchillRev = paramOwn.GetParam("PTC_WM_REVISION")
Dim MedtrStatedRev As IpfcParameter
Set MedtrStatedRev = paramOwn.GetParam("REVISION_LEVEL")
'------------------now create & set rmss parameters
If paramOwn.GetParam(pnRMSS_APPROVED) Is Nothing Then
Set RMSS_APPROVEDnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B13").Value)
Set ipbRMSS_APPROVED = paramOwn.CreateParam(pnRMSS_APPROVED, RMSS_APPROVEDnv)
Else
ipRMSS_APPROVED.SetScaledValue RMSS_APPROVEDnv, Nothing
End If
If paramOwn.GetParam(pnRMSS_APPROVE_DATE) Is Nothing Then
Set RMSS_APPROVE_DATEnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B14").Value)
Set ipbRMSS_APPROVE_DATE = paramOwn.CreateParam(pnRMSS_APPROVE_DATE, RMSS_APPROVE_DATEnv)
Else
ipRMSS_APPROVE_DATE.SetScaledValue RMSS_APPROVE_DATEnv, Nothing
End If
' Dim ipRMSS_CUSTOMER_REV As IpfcParameter
' Dim ipbRMSS_CUSTOMER_REV As IpfcBaseParameter
' Dim pnRMSS_CUSTOMER_REV As String
' pnRMSS_CUSTOMER_REV = "RMSS_CUSTOMER_REV"
' Dim RMSS_CUSTOMER_REVnv As IpfcParamValue
' If paramOwn.GetParam(pnRMSS_CUSTOMER_REV) Is Nothing Then
' Set RMSS_CUSTOMER_REVnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B9").Value)
' Set ipbRMSS_CUSTOMER_REV = paramOwn.CreateParam(pnRMSS_CUSTOMER_REV, RMSS_CUSTOMER_REVnv)
' Set ListTheseParameters = paramOwn.ListParams
' End If
If paramOwn.GetParam(pnRMSS_DRAWN_BY) Is Nothing Then
Set RMSS_DRAWN_BYnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B15").Value)
Set ipbRMSS_DRAWN_BY = paramOwn.CreateParam(pnRMSS_DRAWN_BY, RMSS_DRAWN_BYnv)
Else
ipRMSS_DRAWN_BY.SetScaledValue RMSS_DRAWN_BYnv, Nothing
End If
Dim ipRMSS_DRAWN_DATE As IpfcParameter
Dim ipbRMSS_DRAWN_DATE As IpfcBaseParameter
Dim pnRMSS_DRAWN_DATE As String
pnRMSS_DRAWN_DATE = "RMSS_DRAWN_DATE"
Dim RMSS_DRAWN_DATEnv As IpfcParamValue
If paramOwn.GetParam(pnRMSS_DRAWN_DATE) Is Nothing Then
Set RMSS_DRAWN_DATEnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B16").Value)
Set ipbRMSS_DRAWN_DATE = paramOwn.CreateParam(pnRMSS_DRAWN_DATE, RMSS_DRAWN_DATEnv)
Else
Set ipRMSS_DRAWN_DATE = paramOwn.GetParam(pnRMSS_DRAWN_DATE)
ipRMSS_DRAWN_DATE.SetScaledValue RMSS_DRAWN_DATEnv, Nothing
End If
Dim RMSS_ECO_NUMnv As IpfcParamValue
If paramOwn.GetParam(pnRMSS_ECO_NUM) Is Nothing Then
Set RMSS_ECO_NUMnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B18").Value)
Set ipbRMSS_ECO_NUM = paramOwn.CreateParam(pnRMSS_ECO_NUM, RMSS_ECO_NUMnv)
Else
ipRMSS_ECO_NUM.SetScaledValue RMSS_ECO_NUMnv, Nothing
End If
Dim ipRMSS_ECO_DATE As IpfcParameter
Dim ipbRMSS_ECO_DATE As IpfcBaseParameter
Dim pnRMSS_ECO_DATE As String
pnRMSS_ECO_DATE = "RMSS_ECO_DATE"
Dim RMSS_ECO_DATEnv As IpfcParamValue
If paramOwn.GetParam(pnRMSS_ECO_DATE) Is Nothing Then
Set RMSS_ECO_DATEnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B19").Value)
Set ipbRMSS_ECO_DATE = paramOwn.CreateParam(pnRMSS_ECO_DATE, RMSS_ECO_DATEnv)
Else
Set ipRMSS_ECO_DATE = paramOwn.GetParam(pnRMSS_ECO_DATE)
ipRMSS_ECO_DATE.SetScaledValue RMSS_ECO_DATEnv, Nothing
End If
Dim ipRMSS_ECO_ENGR As IpfcParameter
Dim ipbRMSS_ECO_ENGR As IpfcBaseParameter
Dim pnRMSS_ECO_ENGR As String
pnRMSS_ECO_ENGR = "RMSS_ECO_ENGR"
Dim RMSS_ECO_ENGRnv As IpfcParamValue
If paramOwn.GetParam(pnRMSS_ECO_ENGR) Is Nothing Then
Set RMSS_ECO_ENGRnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B20").Value)
Set ipbRMSS_ECO_ENGR = paramOwn.CreateParam(pnRMSS_ECO_ENGR, RMSS_ECO_ENGRnv)
Else
Set ipRMSS_ECO_ENGR = paramOwn.GetParam(pnRMSS_ECO_ENGR)
ipRMSS_ECO_ENGR.SetScaledValue RMSS_ECO_ENGRnv, Nothing
End If
' Dim ipRMSS_PART_NUM As IpfcParameter
' Dim ipbRMSS_PART_NUM As IpfcBaseParameter
' Dim pnRMSS_PART_NUM As String
' pnRMSS_PART_NUM = "RMSS_PART_NUM"
' Dim RMSS_PART_NUMnv As IpfcParamValue
' If paramOwn.GetParam(pnRMSS_PART_NUM) Is Nothing Then
' Set RMSS_PART_NUMnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B11").Value)
' Set ipbRMSS_PART_NUM = paramOwn.CreateParam(pnRMSS_PART_NUM, RMSS_PART_NUMnv)
' End If
If paramOwn.GetParam(pnRMSS_REV) Is Nothing Then
Set RMSS_REVnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B21").Value)
Set ipbRMSS_REV = paramOwn.CreateParam(pnRMSS_REV, RMSS_REVnv)
Else
ipRMSS_REV.SetScaledValue RMSS_REVnv, Nothing
End If
Dim RMSS_REV_DESCRnv As IpfcParamValue
If paramOwn.GetParam(pnRMSS_REV_DESCR) Is Nothing Then
Set RMSS_REV_DESCRnv = CreoModelItem.CreateStringParamValue(sheets("Parameters").range("B22").Value)
Set ipbRMSS_REV_DESCR = paramOwn.CreateParam(pnRMSS_REV_DESCR, RMSS_REV_DESCRnv)
Else
ipRMSS_REV_DESCR.SetScaledValue RMSS_REV_DESCRnv, Nothing
End If
'Now delete & replace sheet formats from each sheet
For sheetStep = 1 To totalSheets
Dim modelDesc As CCpfcModelDescriptor
Set modelDesc = New CCpfcModelDescriptor
Dim formatMdlDesc As IpfcModelDescriptor
Set formatMdlDesc = modelDesc.CreateFromFileName("rmss-medtronic-11x17-pg1andpg2.frm")
Dim formatMdl As IpfcDrawingFormat
Set formatMdl = CreoSession.RetrieveModel(formatMdlDesc)
If sheetStep = 1 Then
sheetOwner.SetSheetFormat 1, formatMdl, 1, CreoSession.CurrentModel
Else
sheetOwner.SetSheetFormat sheetStep, formatMdl, 2, CreoSession.CurrentModel
End If
Next sheetStep
sheetStep = 0
You need to delete the table from the drawing. The table object (at least in jlink and weblink) does not have a delete method. ie
CreoDRW .DeleteTable(CurTABLE, False)
Hi Randy,
Thanks for the rely. Been looking at this all day now. Can't seem to find a way to relate the Drawing to the Active model.
Tried
Dim thisDrawing As CpfcDrawing
Set thisDrawing = CreoSession.GetActiveModel
but gives a type mismatch
Do you know if I have to do it by Id maybe? As you probably suspect I am not very well versed in Creo VB API, it is a lot different from the Solidworks macros and Excel VBA
Will keep on digging.
Jan
I have never used vba. Instead either jlink or weblink. In jlink to have a drawing you would type the Model to a Drawing eg:
Session session = pfcGlobal.GetProESession(); Model currentModel = session.GetCurrentModel();//returns a Model Drawing drawing = (Drawing)currentModel;//type the Model to a Drawing
oWindow.Activate
Dim i As Integer
End If
Next i
symInst.Remove
On Error GoTo 0
End If
Next
'ITEM_DESCRIPTION
Else
End If
Else
End If
' End If
Else
End If
Else
End If
Else
End If
Else
End If
Else
End If
' End If
Else
End If
Else
End If
Else
End If
Next sheetStep
sheetStep = 0
page 2 of the code:
CreoModel.Save 'Save the converted drawing in Creo format
'Save rmss drawing as pdf
Dim PDFExportInstrCreate As New CCpfcPDFExportInstructions
Dim PDFExportInstr As IpfcPDFExportInstructions
Set PDFExportInstr = PDFExportInstrCreate.Create
Dim PDF_Options As New pfcls.CpfcPDFOptions
' Set Stroke All Fonts PDF Option
Dim PDFOptionCreate_SAF As New CCpfcPDFOption
Dim PDFOption_SAF As IpfcPDFOption
Set PDFOption_SAF = PDFOptionCreate_SAF.Create
PDFOption_SAF.OptionType = EpfcPDFOptionType.EpfcPDFOPT_FONT_STROKE
Dim newArg_SAF As New CMpfcArgument
PDFOption_SAF.OptionValue = newArg_SAF.CreateIntArgValue(EpfcPDFFontStrokeMode.EpfcPDF_STROKE_ALL_FONTS)
Call PDF_Options.Append(PDFOption_SAF)
' Set COLOR_DEPTH value (Set EpfcPDF_CD_MONO to have Black & White output)
Dim PDFOptionCreate_CD As New CCpfcPDFOption
Dim PDFOption_CD As IpfcPDFOption
Set PDFOption_CD = PDFOptionCreate_CD.Create
PDFOption_CD.OptionType = EpfcPDFOptionType.EpfcPDFOPT_COLOR_DEPTH
Dim newArg_CD As New CMpfcArgument
PDFOption_CD.OptionValue = newArg_CD.CreateIntArgValue(EpfcPDFColorDepth.EpfcPDF_CD_COLOR)
Call PDF_Options.Append(PDFOption_CD)
' Set PDF EpfcPDFOPT_LAUNCH_VIEWER(Set FALSE Not to Launch Adobe reader)
Dim PDFOptionCreate_LV As New CCpfcPDFOption
Dim PDFOption_LV As IpfcPDFOption
Set PDFOption_LV = PDFOptionCreate_LV.Create
PDFOption_LV.OptionType = EpfcPDFOptionType.EpfcPDFOPT_LAUNCH_VIEWER
Dim newArg_LV As New CMpfcArgument
PDFOption_LV.OptionValue = newArg_LV.CreateBoolArgValue(False)
Call PDF_Options.Append(PDFOption_LV)
'Set Output PDF File Name
Dim SavePDFpath As String
SavePDFpath = workDir & "\" & CreoModel.FullName & "_rmss_A" 'Creo does not allow spaces in even the pdf file names hence the underscores
PDFExportInstr.Filepath = SavePDFpath
PDFExportInstr.options = PDF_Options
CreoModel.Export PDFExportInstr.Filepath, PDFExportInstr
oWindow.Close
CreoSession.EraseUndisplayedModels '<------Frank Liu Corrected me now works
sFileName = Dir
Loop ' go to the next drawing in the list and repeat
conn.End
End If
MsgBox "All Files Converted"
Set cAC = Nothing
Set conn = Nothing
Set CreoModel = Nothing
End
RunError:
KillCreoAfterCrash1
Set cAC = Nothing
Set conn = Nothing
End Sub
Sub KillCreoAfterCrash1()
MsgBox "There has been an Error"
Dim IpfcAsyncConKAC As IpfcAsyncConnection
Dim CCpfcAsyncConnKAC As New CCpfcAsyncConnection
Set IpfcAsyncConKAC = CCpfcAsyncConnKAC.Connect(Null, Null, Null, Null)
If IpfcAsyncConKAC.IsRunning Then
IpfcAsyncConKAC.End
End If
Set IpfcAsyncConKAC = Nothing
Set CCpfcAsyncConnKAC = Nothing
End Sub
