Warp feature in creo
pburla
Hi Guys,
I want to bend the solid into a cylinder.So i use the warp feature in creo but I am not able to achieve the bend completely.
I am attaching the screenshots .Basically I would like the bend to be complete by ending where it started.
Thanks in advance.
Yep, you can
Creo 2.0 full version attached
7 REPLIES 7
Have you tried a spinal bend feature?
Inoram
(To:pburla)
TomD.inPDX
17-Peridot
(To:Inoram)
Nice one, Matt.
What Matt is showing you is that the part if wrapped 360 degrees without overlap. The hook at the end of the OP's image requires >360 degrees of warp.
Warp can be a tough nut to crack. It is missing some important control features, and others are hidden. It is not ready to replace Spinal or Toroidal bends yet.
BTW, you can probably do this in sheetmetal as well.
Yep, you can
@Matt I did not really get how you managed to wrap it completely with an overlap.Can you please Elaborate a bit on how yopu managed to acheive it?
@Antonious the solution you proposed Looks promising.I just figured out how to use bend and bendback.The geometry which i posted here was a test geometry now I want to use the solution and construct my model.Hope it works.
Thank you for the help
Inoram
(To:pburla)
On your model the little connecting bend is all on one side and 180 degrees. I have half on one side and half on the other side and at 90 degrees each so they face other when wrapped 360 degrees.
pburla
(To:Inoram)
Thank You guys that solved my problem.I owe you guys a beer Cheers
