Weight Error
rmaddy
Weight Error
Im rajesh. Im working in CREO 3.0 version. while in modelling and detailing. some times, I found error an weight. (Analysis\Mass Properties) I will get actual weight after assigning the material. but in drawing we use relation for weight (WEIGHT = PRO_MP_MASS). But it shows wrong valve, in parameter table also I check with weight as pro_mp_mass. but there also showing same error value, how can I solve this error.
BenLoosli
(To:rmaddy)
File-Prepare
Model Properties
Change the Mass Properties
Calculate in that window, then OK and close
Regen your model and the weight will update
We have a mapkey that does that since we tend to change material type frequently.
Mahesh_Sharma
22-Sapphire I
(To:rmaddy)
Rajesh,
Generate report for mass properties using File > Prepare > Model Properties > Change Mass properties > Generate Report > Ok. I hope this will correct the value.
Mahesh_Sharma
22-Sapphire I
(To:rmaddy)
Rajesh,
Did you get the appropriate answer for your question? Kindly mark reply on post as correct answer.
yyuan
(To:rmaddy)
The mass properties can be updated by manually regenerate report. But after updated the mass, the updated part will be treat as same part in Windchill. You cannot checked in. This is an big issue for generating drawings with proper weight info.
