What is the symbol for a "NULL" value?
DELETEME
For relations, I had found and used it once, but can't seem to any find it again. And, of course, the "Help" is no help at all..... I thought it was "||" or something. I'm dealing with a parts list where some of the vendor parts in the assembly have no parameters at all. Since we use a relation: IF asm_mbr_description1 == "XYZ DESCRIPTION3" QTY_REQD = "AR" ELSE QTY_REQD = rpt_qty ENDIF If the "DESCRIPTION1" parameter does not exist, the quantity cells do not populate at all. So, what I want to do is write the relation such that if the "DESCRIPTION1" parameter does not exist, then: QTY_REQD = rpt_qty I thought perhaps if I used the symbol for "NULL" instead of just "" that it would work, but can;t seem to find the symbol to try. Anyone? Thanks!
Try using quotes with no characters between them: IF asm_mbr_description1 == "" QTY_REQD = "AR" ELSE QTY_REQD = rpt_qty ENDIF Hope this helps, Rodney
Have you find the answer since the post ?
Did you try null?
"Willy Chidichimo" wrote:
Did you try null?
